Oh here's some specs..... 1984 tx-19 kustom kraft, dominator pump with B impeller droop and place diverter.... 502 bbc with aluminum heads estimated at 650hp on pump gas I Cant Wait To get back on The water and see she what she will do
well i took theboat out thursday to break it in.... lol it went good at first... we got the cam good and broke in first then set the timing and drove around a lot of time between 2500 and 3000 rpms and then again around 4000 to 4800.... finally we decided to cut her loose..... :smile15:
we was at about 4grand when i punched it... bout two seconds later i look and we running 5500 rpms and then a dead silence and we are just skipping across the water with no power.... one of the wires vibrated loose and threw the breaker.... it was a scary feeling moving that fast and having no control... it was about dark and since i had it wide open it was way flooded down so we got towed in..... but all in all the i felt pretty good about the day cause when the breaker killed it is was far from done... i cant wait to get back on the water
