spd500 said:Might be cheaper to find a box already made than to buy a bender to try to make one think.gif
spd500 said:Hopefully something that looks good enough to mount on the top of the motor ?
SimplyOrange said:spd500 said:Hopefully something that looks good enough to mount on the top of the motor ?
glad makes a disposable food stroage box
im trying to make up a project to use the bender, sounds fun....but all my windsheilds use flat pieces.a clear engine cover would be sweet!
I wouldn't do that, if you seal it up its gonna sweat and corrode! Either buy a Marine MSD or mount it up front where it is less likely to get wet.spd500 said:How much to build a water tight box to mount an MSD on my motor ?
spd500 said:I think if you made two interlocking U shaped pieces you could do it with just simple bends , thats how I have always made steel boxes . But I have no idea what to do with plastic bending , never messed with it .
KONA said:spd500 said:I think if you made two interlocking U shaped pieces you could do it with just simple bends , thats how I have always made steel boxes . But I have no idea what to do with plastic bending , never messed with it .
get youself a good heat gun and plexi, lay it over a metal table edge and go to town think.gif
spd500 said:Not even sure where Mckinney is , but since you hang out with the North guys I am going to say probably not . I am in Crosby , by Houston .
spd500 said:KONA said:spd500 said:I think if you made two interlocking U shaped pieces you could do it with just simple bends , thats how I have always made steel boxes . But I have no idea what to do with plastic bending , never messed with it .
Not a bad idea . Will it work with any lexan ? Or is there a certain grade for bending ?
Gotcha, but keep in mind that anything you seal up like that is gonna get wet from condensate if it cant breathe to atmosphere unless you pull a vacuum on it and fill it with dry nitrogen.spd500 said:They don't make this box in a Marine application yet . It's the control box for my LS .
