Was on the boat tonight after work made it off the trailer and the motor was ideling fine and just died like you turned the key off. I had fuel in the filter and when i hit the carb fuel would go down the carb. I have a 460 with MSD ready to Run and a Marine 6m2 MSD box. After a few minutes i was able to get it started and back on the trailer. When it was on the trailer still in the water of course It fired up ran smooth for a few minutes then died again just like if you were to turn the key off. Im look for some suggestions if it happens again this weekend weres a good place to start ?? I can bypass the MSD box if need be
Thanks for any feed back.
