What type-brand header gaskets are good? I'm tired of changing mine!!
SimplyOrange said:two coppers on each side, problem solved
Crusader said:SimplyOrange said:two coppers on each side, problem solved
Two copper gaskets on each header? Where do ya get them?
Crusader said:Like these Bobby?
http://www.summitracing.com/parts/sum-111436
That's what I use as well! They work great! clap.gifDuanehydro said:Percy's aluminum crush gaskets work well. Expensive, though. The copper I've never used but have a set for a 460....they are used once, but free.
Crusader said:Patch....they cured your exhaust leaks?
I had real good luck on Brent's with a large flat B a s t ard file.....and a straight edge....took about 2 hours.Crusader said:Ya, okay....I think you're correct.
Bobby...hope I'm not hijacking your thread here..... Do you know of a machinist nearby that I can take my logs to and have them machined flat?
