So after getting this pig all together and running well after changing a couple of injectors it's been starting to lose RPM's again. Pulled the plugs yesterday and two were clean, like not running clean. Removed the two corresponding injectors and they have crud in them from the inner lining of the rubber fuel hose. It IS EFI hose too. The supply line is now about a foot of rubber EFI hose from the tank to the filter. A couple inches of rubber hose from the filter to the hard line which runs all the way to the engine compartment, then about another two feet of rubber hose back on the motor. The entire return line is rubber hose.
I think the ethanol in the gas is deteriorating the inner lining of the hose, maybe? Cleaned the crud out of the injectors and it runs like a scalded dog again.
Is there another type of EFI hose that is Ethanol friendly? The crap from O'rielly's is obviously NOT.
