FOOD FOR THOUGHT
TexasJet
This is a bit dated but you get the idea.
Subject: DEFINITION OF ACCELERATION
As promised, here is a definition of acceleration.  Hope you enjoy the read as much as I did.
mj
DEFINITION OF ACCELERATION:
One top fuel dragster 500 cubic inch Hemi engine makes more horsepower than
the first 4 rows of stock cars at the Daytona 500.
It takes just 15/100ths of a second for all 6,000+ horsepower of an NHRA Top Fuel dragster engine to reach the rear wheels.
Under full throttle, a dragster engine consumes 1-1/2 gallons of nitro methane per second; a fully loaded 747 consumes jet fuel at the same rate with 25% less energy being produced.
A stock Dodge Hemi V8 engine cannot produce enough power to drive the dragster's supercharger.
With 3,000 CFM of air being rammed in by the supercharger on overdrive, the
fuel mixture is compressed into a near-solid form before ignition.
Cylinders run on the verge of hydraulic lock at full throttle.
At the stoichiometric (stoichiometry: methodology and technology by which
quantities of reactants and products in chemical reactions are determined)
1.7:1 air/fuel mixture of nitro methane, the flame front temperature
measures 7,050 deg F.
Nitro methane burns yellow... The spectacular white flame seen above the
stacks at night is raw burning hydrogen, dissociated from atmospheric water
vapor by the searing exhaust gases.
Dual magnetos supply 44 amps to each spark plug. This is the output of an
arc welder in each cylinder..
Spark plug electrodes are totally consumed during a pass. After halfway,
the engine is dieseling from compression, plus the glow of exhaust valves at 1,400 deg F. The engine can only be shut down by cutting the fuel flow.
If spark momentarily fails early in the run, unburned nitro builds up in the affected cylinders and then explodes with sufficient force to blow cylinder heads off the block in pieces or split the block in half.
In order to exceed 300 mph in 4. 5 seconds, dragsters must accelerate an average of over 4G's. In order to reach 200 mph (well before half-track),  the launch acceleration approaches 8G's.
Dragsters reach over 300 miles per hour before you have completed reading  this sentence.
Top fuel engines turn approximately 540 revolutions from light to light!
Including the burnout, the engine must only survive 900 revolutions under
load.
The redline is actually quite high at 9,500 rpm.
Assuming all the equipment is paid off, the crew worked for free, and for  once NOTHING BLOWS UP, each run costs an estimate $1,000.00 per second.
The current top fuel dragster elapsed time record is 4.428 seconds for the  quarter mile (11/12/06, Tony Schumacher, at Pomona , CA ). The top speed  record is 336.15 mph as measured over the last 66' of the run (05/25/05 Tony  Schumacher, at Hebron , OH ).
Putting this into perspective:
You are driving the average $140,000 Lingenfelter 'twin-turbo' powered Corvette Z06. Over a mile up the road, a top fuel dragster is staged and ready to launch  down a quarter mile strip as you pass. You have the advantage of a flying  start. You run the 'Vette hard up through the gears and blast across the  starting line and pass the dragster at an honest 200 mph. The 'tree' goes  green for both of you at that moment. The dragster launches and starts after you. You keep your foot down hard, but you hear an incredibly brutal whine that sears your eardrums and within  3 seconds, the dragster catchesand passes you. He beats you to the finish  line, a quarter mile away from where you just passed him.
Think about it, from a standing start, the dragster had spotted you 200 mph
and not only caught, but nearly blasted you off the road when he passed you
within a mere 1,320 foot long race course.
...... and that my friend, is ACCELERATION!
And that is why GUYS LIKE CARS!
Good summary showing racing = rich mans's sport. :cheesy: At least with the 'vette you can keep cruising, same can't be said for the dragster. :grin: Pretty cool knowledge/trivia... :cool:
I've seen this before, but it is always fascinating to see again.
The part that amazes me is 1 1/2 gallon of fuel per second.  If you turned a 1 gallon can upside down, it would take about that length of time to empty the can.
Of course, an engine that is only good for about 900 revolutions before needing a complete overhaul doesn't say much about the engine durability.
Sort of make you wonder about wanting a Hemi, at least it's not a Chevy or Ford.
FL350 said:
Pretty good read, but I would like to know where they got there info on the 747???
If it's on the internet, it must be true, factual and unbiased.
    think.gif  That's a fact!
WFO
I thought this is always really cool. I think this is old info though because now they say a Top Fuel Dragster makes like 10,000 hp. This is a estimation because there is not a dyno top measure that. " FEEL THE EARTH MOVE"  jump.gif
