Devilman said:This isn't it?
http://www.summitracing.com/parts/nal-88862587
About to put JD's motor back in his 30 ford roadster.Devilman said:No problem George. Summit showed 2 different part numbers, one was available & one was not. But the descriptions both read the same?
Whatcha working on? :grin:
Uh OH! That ought to be interesting! :smile14:pro53 said:About to put JD's motor back in his 30 ford roadster.Devilman said:No problem George. Summit showed 2 different part numbers, one was available & one was not. But the descriptions both read the same?
Patchman said:Uh OH! That ought to be interesting! :smile14:
This one is not correct! :smile23:Devilman said:Gotcha. I googled it in the meantime, turns out its an old school hot rod thing that can work pretty well, when done correctly of course. :grin: Learn something new every day.
Patchman said:It will! It's actually a killer combination when done right. This one just wasn't right.
Probably a mix of both! :smile14:jimsplace said:Patchman said:It will! It's actually a killer combination when done right. This one just wasn't right.
Are you still talking about the engine or someone we know?
