Brazos River Rat ( Billy ) said:If you ask Jim , be prepared to order some center cut Douglas fir from California at about a 100.00 per board , then properly treat the wood and seal it , then drill oversize bolt holes and fill them with resin and then re-drill the correct size bolt holes through the center of the resin holes so the wood is protected all the way through and no way water will get to the wood .. Jim bolted his on with stainless bolt and nuts also I believe .. I wish I could do mine like that , but I don't have the money or the time for that .. It does look good and will outlast his trailer for sure .. No offense Jim , just picking on you a little .. It kind of slow in here ..
FL350 said:Brazos River Rat ( Billy ) said:If you ask Jim , be prepared to order some center cut Douglas fir from California at about a 100.00 per board , then properly treat the wood and seal it , then drill oversize bolt holes and fill them with resin and then re-drill the correct size bolt holes through the center of the resin holes so the wood is protected all the way through and no way water will get to the wood .. Jim bolted his on with stainless bolt and nuts also I believe .. I wish I could do mine like that , but I don't have the money or the time for that .. It does look good and will outlast his trailer for sure .. No offense Jim , just picking on you a little .. It kind of slow in here ..
LMAO!! That's some funny s*** right there! And probably true!!
Very good advice about the air stapler, that's almost a must have for doing it. You'll use a ton of staples.Chevy2184 said:If you don't have one? Borrow a air stapler or a electric one... That's a chit load of staples lol
Sent from my shop setting in my boat making motor noises
jimsplace said:FL350 said:Brazos River Rat ( Billy ) said:If you ask Jim , be prepared to order some center cut Douglas fir from California at about a 100.00 per board , then properly treat the wood and seal it , then drill oversize bolt holes and fill them with resin and then re-drill the correct size bolt holes through the center of the resin holes so the wood is protected all the way through and no way water will get to the wood .. Jim bolted his on with stainless bolt and nuts also I believe .. I wish I could do mine like that , but I don't have the money or the time for that .. It does look good and will outlast his trailer for sure .. No offense Jim , just picking on you a little .. It kind of slow in here ..
It's almost totally true.
The boards were purchased locally, but they were still expensive and more than $100 each.
In order to get fine grain without knots redwood, it will be wood from the old redwood trees, which is getting harder to find. Very few places will have it locally.
I also used 3/8 inch flat head stainless screws in order to keep the head flush with the board after countersinking the epoxy resin hole (pillar). Before installing the screws (bolts) I cut a slot in the end of the screw so that if they ever became lose, I could hold it with a screwdriver and tighten the nut. With the carpet attached, you can't get to the head to hold it from the top.
For the carpet, I went to an auto upholster supply and purchased the black carpet used for trunks and then used two layers for added cushioning and a more even support.
My bunks were 8 1/2 or 9 feet long, the redwood could have been bought from California much cheaper if they were 8 feet or shorter. The shipping killed it with oversize charges.
There is another wood that water doesn't effect too, but I don't recall the name. It's from South America and cheaper.
After finding a bunk loose at the lake, I don't want to ever have to worry about that happening again.
Definitely use stainless bolts and staples. Most of the time you'll find the bolt has rusted and broken or the wood has rotted away.
There you have it folks. 6 months later and 2000 man hours you can have a trailer like ol Jim!
:smile17:FL350 said:There you have it folks. 6 months later and 2000 man hours you can have a trailer like ol Jim!
GOOD SUGGESTION ABOUT THE DUCT TAPE.Brazos River Rat ( Billy ) said:I carry a roll of duct tape or electrical tape with me . I am prepared for this when it happens .. Just wrap the rape around the bunk and down to the support and you are good to go for a few more trips to the river .. It actually works pretty dam good to get you home ..
Not sure why we are talking about this . look like we will not be going to the river or lakes for a while .. :smile18:
