HellinnFrnt
ok here's my deal. My shop is using a 50hp Des-Co rotary 3 phase converter and it has recently started burning out the start capacitors (250v 270-324 mfd) 14 cap stack (total) run caps are 370v (not sure mfd) 8 total. The property owners electrician came out and replaced some of the start caps with 330v 270-324 mfd and it worked fine for a few weeks but has blown 2 more 250v out 2 times since ... (each time it has been the 250 next in line after the 330v). The only difference I've been able to see is some have "bleed resistors" some not. I know for sure that the last in each "stack" has one. I don't think the voltage rating is the problem but I AM wondering about the resistors and also what effect the start timer may have on the system. When it doesn't start it seems to stay "engaged" longer than normal (usually about 3 seconds) when it blew Friday I counted to 6 before I pulled the switch on it. I could hear the motor up and running it never seemed to kick out the start circuit like it normally does (loud buzz for a few seconds then quiet smooth motor sound) it stayed at loud buzz for 6 seconds before I shut it down, opened motor room and magic smoke was floating out of the box. OK get the picture ?
Question...
(1) How do I check the start timer (potential relay) whatever it's called? (seems likely to me it's sticking sometimes)
(2) What is a SAFE way to check the caps in the stacks?
(3) Does anyone KNOW how to work on something like this that I can send pics and talk to?
(4) How do I keep the smoke INSIDE the caps?
We're willing to pay some one that knows what they are doing to come out and fix it. If it's going to cost 3k to fix we can get a whole new one but would need it installed. Our only other option is move to a new building that already has 3 phase and that could be upwards of 25k in moving and installation/setup.
Thanks for your time....
Question...
