Newbie .. but not new to projects.
99 Liberator 21' .. appears to be a theft recovery as it's completely stripped.
Found in Georgia and saved from someone that initially had intentions of cutting up and converting to a flats fishing boat ... So get her home and start investigating how much work it really is going to need. Transom / side bulkheads / Dash wood and side rail wood. Pretty much anywhere wood was ... will have to be redone. So time to get dirty. Decision was made to take the back deck cap off so we can make sure the transom gets removed right and reinstalled right. I KNOW ... some of you are probably staring at your screen with your mouth open far enough that a buzzard could fly in ... but there's very good reasons why we went this way. Here the main reason why.
Don't have a pic (you'll see why later) of the other reason but will have in a couple of days.
So the cap comes off. Didn't take but about 2 hours to have most of the 2 piece transom out. Then ... "Houston we have a problem" ... while cutting literally the last piece of glass to start removing the second half of the transom ... cutoff wheel binds ... walks up the transom ... and decides to make mince meat of my wrist. PROJECT ON HOLD until this thing heals.
In the meantime .. this allows me some time to start the project thread like I promised Cliff a while back. Plans are to get back on it SOME this weekend.
Plans for this are to naturally redo all the wood that is rotten... redo the transom for an outdrive (Blackhawk on the way) ... flip it and blueprint the bottom / regel ... then flip and regel (multi-color) the top. Powerplant for this will start off as (most likely) a semi stock ls engine to get to the water .. but by sometime next year .. plans are to build a blown (8.71) 6.0 LS. This should interest FormulaZR and Blazeracer to say the least.
I'll try and keep this updated as much as I can but since I have a 9-5 ... work will only take place on the weekends so progress will be slower than some other builds. I should have some more pics if nothing else come Monday or Tuesday.
