Putting it up sor sale, seeing if there's any interest. If it sales great, if not I'll keep and enjoy it untill it does. Not getting out of the boat scene but looking to go bigger.
Boat is a 1994 Ultra tunnel, original paint in great condition. Original setup/rigging from Tom Papp. Has two polished 12gal saddle tanks (pulled and cleaned out Feb. '13). New steering cable and new Gaffrig GPS speedo with recall in 2012. Kill switch. Custom trailerable cockpit cover. Polished fire extinguisher. Fiberglass seats. All gauges are Gaffrig: speedo, tach, boost, oil psi, water temp, hour meter, oil temp., all with anodized bezels. Anodized battery tray with Optima red top battery. Splash gaurd on transom. 3 bilge pumps. Solid floors and stringers.
Winter of 2012-Spring of 2013 pulled engine out of the boat for a rebuild. Originally powered by stock 502 with 6-71 wieand blower. Had KPE (http://kperacing.com/) do the rebuild. 502BBC bored .030" over to 509ci, BDS 8-71 blower, Teague super chiller, Manley H-beam rods, SRP blower pistons, Clevite Hell fire file fit rings, Comp cams hydraulic roller cam, Manley severe duty marine valves-dual springs-retainers-locks, MSD billet distributor, MSD high vibration coil, Moroso ultra wires, ATI balancer, Miziere Billet Flexplate, chrome timing cover, chrome plated 10qrt pan, chrome coil mount, new puke tank, valve covers w/ male -12an welded on, Dooley air scoop, and JET HOT coated Bassett twistie headers. Dyno'd 794hp at 5800rpm, 16% under driven w/ 4.6lbs boost. New chrome 1-wire alternator. All AN fittings are new polished fittings with new ss hoses. 12hrs run time since rebuild. http://youtu.be/TnzQYLIB8U0
While engine was out I pulled the old carpet out of the boat and cleaned up the floor. Had all the pieces aluminum pieces anodized to match, installed new anodized fuel fills, and went back with all new polished fasteners. Installed oil temp and hourmeter gauges. Installed new anodized overboard dumps (2 for eng, 1 for cooler, 1 for bilge)
Berkley pump with droop, hyd diverter, billet inducer, jet-away rachet, loader, and ride plate. Not sure what cut the impeller is, a pump rebuild was next on the list but haven't done it yet. Works fine the way it is.
Trailer also redone late 2012 with new paint, new led lighting, new boards, new carpet and new winch. Front of fenders are sprayed with rock/chip gaurd. Also has spare mounted on trailer.
Have receipts for all engine work, polishing/anodizing/chroming/coating. Great turn key 85-90mph boat. $20,000 OBO
Message me or call me if interested (409) 466-1619 John Located in Vidor, tx
