Patchman said:So do you prefer the draw through over a blow through setup. Or do you choose that route because of the parts already available? It looks great, and I really want to turbo a boat. Keep us posted please! :grin:
spd500 said:I dont know that it makes more power , but I really like the draw through systems. They are really cool looking , and you can test out different carbs without spending a fortune on blow through carbs .
jimsplace said:Patchman said:So do you prefer the draw through over a blow through setup. Or do you choose that route because of the parts already available? It looks great, and I really want to turbo a boat. Keep us posted please! :grin:
For the best information about setting up a turbo, E.O. is as good as it gets around here. I am sure there are others also, but he can speak on the topic very well.
I just recently got involved with a turbo motor and am excited about it. One thing I know is, if you put a turbo on it, make sure the motor has a strong bottom end. Turbos don't know when to stop making power.
spd500 said:Why are the draw through systems not able to make the same boost and power? It seems like it would be a very small difference from one to the other, as long as you get more fuel and more air you should make more power.
. That's hauling a$$!!EOSpeed said:IF YOU WANT TO MAKE BIG POWER THE BLOW THROUGH IS THE WAY TO GO. A C&S CARB AND BIG TURBO YOU CAN MAKE 1500 TO 2000 ON ALKY. THE 468 IN MY 18 WILL PULL A AA IMP. 6000 RPM EASY. IT 7.5 COMP. AND 15 PSI ON PUMP GAS WITH THE BIG COOLER.
