All right guys, bear with me and my ignorance on this topic.
I don't have a picture at the moment however I'll describe the best I can.
I'm assuming that were the drive shaft from the engine enters into the pump is where the Thrust bearing is located. Yesterday, while I was on the lake, I noticed I was getting more water than usual into the bilge area. I drained it out and then decided to investigate. What I found was a slight drip of about one drop per second dripping from what I think is the Thrust bearing......this is while floating and not underway. I do grease is about every other trip out on the lake.
My questions are:
1. Is this normal for the bearing to drip like that?
2. If indeed it is NOT normal for it to drip, how hard is the bearing to replace?
3. If I have to replace the bearing, do I have to remove the engine?
4. Do I have to remove the whole pump assembly?
Thanks a lot for your time fellas.
Cliff
My questions are:
Cliff
