Rubrail
itsjohny
Im trying to deicde on a rubrail and it seems like there not to many options for the size i need. The actual size top to bottom of the lip where it would go is 3/4. I cant find one that take a ruber insert that is 3/4.. found a few half moons. Any suggestions, how do the half moons look?
Pics of it installed start in the last post of this page.
http://www.texashotboats.com/forums/index.php?topic=11360.45
Speed was correct Rubrail.com.  Nice guy good price but expensive to ship.  The have everything and he can make good suggestions for you.
We were both correct.  rubrail.com has a bigger selection.  rubrailS.com is where I got mine.
itsjohny
Matt, how big was the outer edge Of your boat ( where the rub rail goes)? I wouldn't mind the half moon if they had it in 3/4
The edge is fairly small on the Rebel especially around the front.  They do have it in 3/4.  ALO-28  4th one down
http://rubrails.com/aluminum_half_oval.html
Do you have a nose piece on the Rebel or did you just wrap it around with a little heat? I have to get a rub rail for the Enforcer and will probably go with ALS-16, third one down, cause the cap has a bit of a lip on the lower half of the hull. that or ALS-21, 9th one down.
http://rubrails.com/aluminum_solid.html
