Does the early model 302 and 289 share the same crank and if so does it take the same harmonic balancer?
customtouch said:Anyone know what the plug gap should be set at when running a Jacobs ignition. They were all set somewhere between .060-.065 which seems a little excessive to me unless the Jacobs system put out one hell of a spark. I haven't found much info on them yet either.
Patchman said:Check the date on the block casting number. 302 didn't come out until 1968. :smile16:
Duanehydro said:If built 20 years ago, it could still be a late model 5.0, which uses a 50 ounce imbalance. It's easy to tell, the weight is twice the size on the flywheel and balancer.
Duanehydro said:If it were the wrong balance, you woouldn't be able to sit in the seat....lol :smile26: when they are wrong, you know it, right off.
Devilman said:customtouch said:Anyone know what the plug gap should be set at when running a Jacobs ignition. They were all set somewhere between .060-.065 which seems a little excessive to me unless the Jacobs system put out one hell of a spark. I haven't found much info on them yet either.
I've got Jacobs Ignition stuff on my Lightning, when putting it on there it was in the instructions to open the gap up from stock, up to .055 - .060... something like that. Wasn't happy with their wires though, they came apart like a cheap suit. In their defense, they did offer replacements at no charge.
customtouch said:Patchman said:Check the date on the block casting number. 302 didn't come out until 1968. :smile16:
These are all the numbers I have found C80E-6015-A 9814 and 4172077 stamped on top rear. (PS) I had a helper retrieve them for me so they may not be 100% accurate.
blazeracer said:customtouch said:Patchman said:Check the date on the block casting number. 302 didn't come out until 1968. :smile16:
The numbers look to be right. 68/69 302 out of a Mustang. SHOULD have 302 cast into the lifter valley although may have a 289 marking. It was still a 302 and NOT a Boss. That would read C9ZE
