need lots of help guys
txcrusader
i had the boat out this past weekend  and had a problem the boat ran great but the pump on the out side of boat where the bowl meets the berkley plate on transome was spraying out water is there a gasket there ???? that blew ..there is a lot of silacon there around the bowl looks like it blew the sealer out. is there a shop around here that can fix the problem thx a million ,matt
The area you are talking about is supposed to have a big O-ring that seals the transom adapter/cover to the bowl. Sometimes people will leave them out & run silicone around that area instead.
Water was spraying inside the boat or outside?
Yup, good call on bowl to pump gasket. That one would definitely spray!
Either way, not too difficult a fix... More time consuming than anything else.
txcrusader
water was spraying on the out side i know did not look at the inside. right before i knew it was sprying out i was looking at the back because it was just reving up and no thrust thats when i saw it spraying out almost like something was stuck in the pump i finally got the boat on plane and it was fine coming out of the hole but still spraying out the top any of yall live near new braunfels tx iam new to the jet boat stuff never had a pump out before just the engine thx guys ,matt
Sounds more like the bowl gasket, like Coonass was sayin, with it spraying like that. Far as a shop in your area, not sure. Richard/Esabataj is up by you, you may shoot him a PM & see what he can tell you about it.
Couple other guys in your area are Nick/Sleek460 & Keith/77Spectra. If nothing else & you decide to tackle it yourself, there more than enough guys on here to chime in with tech support. Not a terribly difficult job, but will be kinda time consuming.
Robert
i am in houston,if u are wanting some one to fix it for u, also can meet u in katy if u want,u are looking at about 250.00 to pull pump and install all new gaskets,robert 713 208 7447  thanks
badblood
The pump is nothing to be afraid of, it is very simple. If it is spraying water you have a bad gasket. Pull the bowl off and Ill bet you find your culprit. You will have to mail order gaskets, but worth the trouble to do it your self. When you put it back together dont use silicone on the gasket. Seems to make em easier to spit out.
Good luck
