Here is my extremely cheap build......
Its a 16' 1984 Cimarron SJ. Came from the factory with a 350 and a 12JE pump.
Two years ago I bought it and stuck in an 8:1 350 with a nice little hydraulic cam (I had the motor sitting around). Had problems with #7, turned out it ended up scoring a cylinder wall. Yanked the motor out and it sat for a bit.
Plans:
Rebuild the pump.
I put a Place Diverter on it 2 years ago.
Currently wet-sanding it and buffing the hull.
4.8L LR4 with 320,000 miles (still runs STRONG). I figure the cold block will tighten up the ring seal a little.
It should turn a B impeller 4300 rpm buy my estimation.
Also just received my order of stainless in to build some water jacketed headers. (will be about $100 cheaper than buying the PCM manifolds/risers, and look WWWAAAAYYYY better painted or polished).
Goals are a very reliable family lake boat that does around 60. Keeping the fuel injection. I'm using a 4.8 because it was FREE. Not hard at all to bolt in a 5.3 or 6.0 or 6.2 later down the road.
It did 60 mph (GPS) with the 8:1 cammed 350, hoping this 4.8 will be just as fast, but be more reliable (EFI) and better economy (I'm saving my 76 Rogers Bonneville for the hot-rod boosted LSx)
I will be doing the tuning with HPtuners.
The first 2 pics are from 2 years ago. The last one is from over the weekend from wet sanding and buffing (don't think its ever even been waxed).
Oh and yes, it is wrong hand drive.
Plans:
Rebuild the pump.
