Here is everything i know about my boat and engine AND what i would like to accomplish with it.
1976 Sanger Super Jet 533 Cubic Inch Ford Stroker Engine Eagle stroker crank, H beam Rods, JE Pistons, ARP Stud Kit Edelbrock aluminum heads, Hyd Lifters & Cam, Prop Comp roller rockers, Pete Jackson Gear Drive, MSD Billet Dist& Ignition with Soft touch rev control, Hot Foot pedal Offey Tunnel Ram with dual 750 Edelbrocks Engine machined and assembled by McMurtrys Racing Engines. Pump rebuilt by Hi-Tech Performance it has 9 Vein Split Bowl A-2 Impeller The Snoot with 2 wedges and Hydraulic Place Diverter with steering wheel control.
The man who put together the engine says it should produce around 632 HP. I love the look of a massive engine. Esp. a blower. Im not into racing it. I want to the engine to produce 1000+ HP. I am totally set on a blower, i'm just not very knowledgable on engines, esp. blowers and such. I talked with Don hampton and a few People from 460Ford.com and they all tell me my components are good except the cam and compression asspect.
My compression now (as far as I know, according to the machinest) is around 9.5-10:1. If it is that high, could i just run ethanol? THank you
