This is how my boat came when I bought it, If you remember I once had logs with thru-transom exhaust. As you can see in the first picture water came out of the block into the homemade snails that went
down thru the transom.
It wasn't a problem until I bought the over the transom snails. I really don't remember for sure if I had flappers or not, I really don't think that I did. (Pic 2)
Either way at the extreme angle to go back up through the logs water coming in was never a problem. How to fill a fresh motor with water 5 min after firing it up for the first time: 1) Run water exactly as it was when you had thru-transom exhaust! (By the way there are no seep holes in logs or snails!!!) 2) Run motor full of confidence for 5 minutes setting timing and generally feeling good about having an new bullet in boat. 3) Pull hot wire from distributor while water is flowing heavily from newly configured over the transom snails. 4) Wait for water that you were somehow able to push up through the snails to come running back down in cylinder heads, so as to fill all cylinders full completely full of water.
(Video)
http://www.youtube.com/watch?v=u7uHv732GYc&feature=youtu.be
Really the only way to properly break in a fresh boat motor as far as I am concerned is to spend good money on Castrol 20/50 Racing oil, only to have to drain it all out after adding a gallon of water to it! I'm not even going to mention the hydro-lock situation that had me convinced that my starter went bad over the winter, and had me searching 10 auto parts stores to find another starter. (Idiot[/]
at all parts stores)..."What did the starter come off of?" (
Me) "A boat. It's a 350 Chevy starter, how difficult could it be to match it up?"
Devilman said:
What is it exactly that the snails do on log exhaust? Serve as sort of a P trap (for lack of a better description) to keep water from gettin into the engine.... muffling engine noise... ?
It does have water lines going to them, to cool the flexible hose I assume?
Just curious if this setup is something I could run & what would be the reason for this over the other.
Thanks!
I'm sure that the water lines are just going to the snails for no other reason than to discharge water from the block, not for cooling or any other reason. As long as the water coming out of the logs is going downhill there is no reason to have to have another water outlet coming out of the back of the boat. After going uphill I had to add the ugly hose going over the back of the boat to get the majority of the water cycling through to exit. (Pic 3)
My .02
Devilman just started a thread to see whatever happened to Wakemaker, surely he can't lay off this one! think.gif
