taylorjet37
i have a 460 in my jet boat. i have a problem need some help. i will be cruising or just idleing and it will loose all power like someone reached up and turned the key off. turn the key off and let it sit for a sec. it might or might not come back on when you turn the key back on. i replaced the ignition switch cuz it seemed wore out plus a wire broke when i was changing it. took it back out again and it did the same thing. im wondering if it is the solenoid. this is my first ford. the way it goes is from the battery to the solenoid then to the key so it has to be something in between there. the power to everything (fuel pump, bilge pump and power) comes thru the key. any suggestions would help.
