Ford parts
jdeaton
Need to get rid of these Ford parts.
Make offer:  8 TRW 30 over high compression pistons.  One piston is not usable.  New piston is $56.00.
                  8 Ford Hi performance Rods C9AE
                  2 four barrel cast iron intake.  One for car (blue), one for jet boat (black)
                  1 pair Ford heads fresh from machine shop coated with grease for storage.  Checked for cracks, decked and ready for assembly, all parts (valves, 2 sets of springs, and lifters) part # D2VE-AA.
                  And Misc parts Harmonic balancer, distributor, valve covers, rod caps.
In the third picture you can see the chip out of the bad piston, it's the center piston, at the top, right where the valve pocket is.
            l      Also brand new Pro comp aluminum heads with after market (good stuff) valves, springs, etc. and Ford motorsport aluminum valve covers.
                    How about $1400 for everything?  979-451-3609  Jim
jdeaton
Just added a Ford pressure plate to the package.  Ford # E7TZ  priced around $195.00 on E-bay.  Sell everything for 1400.00 or cut out the heads and sell the rest for $500.00.  Offers? Anyone? Buller?
jdeaton
Here's the Procomp information.  I bought the heads bare and had better valves, springs, and hardware installed.  I think the springs were set up for that solid lifter cam I was going to use.  I think I sold the cam to Tanner, He would have the specs on it.
Procomp Motorsport's 3051 BBFord 429/460 Aluminum Cylinder Heads, PAIR (2 heads)
356-A Aluminum Alloy Heat treated to T-6 Specifications.
Patterned after the popular Edelbrock heads, Fully CNC'd Machined,
95cc Combustion Chamber, Open Chambers, 300cc Intake Runners, 100cc Exhaust Runner,
.400" thick deck for use with nitrous, ultra high compression, and turbo/superchargers.
Oval Ports-Intake 2.005"x 1.510" Exhaust 1.8125"x 1.375",
3 Angle Cut Stellite Valve Seats Hardened, Valve Seats cut for 2.190" Intake & 1.710 Exhaust
Designed to withstand blowers, turbos, and nitrous).
Manganese Bronze Valve Guides,
S/S Intake Valves- 2.190/ Stock, S/S Exhaust Valves- 1.710/ Stock
4140 Steel Retainers 1.400 x 1.060 x 0.690,
7 deg. Valve Locks +.145
8005 Single Spring w/dampner, springs are designed for big block motors that require a 1.5250 outer diameter spring. Springs are designed for street/strip applications with cam combination with no more than .690-.750 lift. Spring pressures and installed heights are as follows.
140lbs at 1.900
165lbs at 1.850
180lbs at 1.800
350lbs at 1.300
365lbs at 1.250
380lbs at 1.200
Coil bind at 1.160
jdeaton
These parts are still for sale.  Head deal fell through, will have all the parts loaded and could deliver to Conroe Swap this weekend. Someone out there needs this stuff, Make me an offer. :smile27:
jdeaton
Add a C-6 automatic transmission with torque converter to the Ford Garage sale.  The transmission is the 335 series 7-3/4 top bolt pattern out of a 429-460 big block, the tail shaft is 14 inches and gear ratio is 2.46, 1.46, 1.00.
jdeaton
Here's the Craiglist ad for the parts.  Anyone need anything, call me.
http://houston.craigslist.org/pts/4104867680.html
