EDELBROCK HEADS NEW
EOSpeed
Member
I HAVE A NEW SET OF EDELBROCK PERFORMER RPM HEADS OF 1600.00.      817 996 4431
EOSpeed
Member
IF NO ONE WANTS THE HEADS I AM GOING TO PUT THEM ON E- BAY.
        :smile19:
Those are nice heads.
If anyone is considering an upgrade, they are well worth the price.
EOSpeed
Member
1480.00 THAT IS MY COST. BUY THEM OR I WILL PUT THEM ON THIS 439 I AM BUILDING.
EOSpeed
Member
I WILL BE HEAR. GIVE ME A CALL.
EOSpeed
Member
DUANE I SOLD THEM. WHAT ARE YOU LOOKING FOR? I HAVE SOME MORE.
looking for small port (462 motor) either oval ports or small req. ports, setup for solid roller .660 Lift, aluminum
Eyeballing the Brodix ovals...
EOSpeed
Member
118 CC CHAMBER
315 CC INTAKE
110 CC EXHAUST
2.25 INT. 188 EXH
185 LBS @ 1.95 465 LBS @ 1.375  COIL BIND 1.15
SAME HEAD THAT GM PUT ON THE 572 RATED AT 620 HP.
1780.00
EOSpeed
Member
ALL OF THE GM STUF HAS BEN CUT OF.
What are your thoughts on these versus an oval port 280 brodix heads on a 462" motor? think.gif
Seeing as how it's probably only gonna turn 5600-5700?
EOSpeed
Member
HOW MUCH DURATION DO YOU HAVE @ .050. WHAT IS THE C.L. INTAKE MANIFOLD, COMPRESSION RATIO.
10.2 w/119, 660 lift 264/264 dur @.050 clay smith roller. Cut on 108. Shootout 4150 single plane w/dominator adapter 1050cfm holley
Also, Eo, this is my only ride....My wife and I will be cruising this thing everywhere...god willing..so throttle response/midrange/cruise is important, as well as a lil' top end from time to time... :smile16:
NOT a race boat. :smile28:
EOSpeed
Member
WITH THAT MUCH CAM THE BRODIX 280 WILL BE THE BEST. WITH YOU COMBINATION IT WILL MAKE 600 HP @ 6000. THE 108 C.L AND THAT MUCH DURATION IT WILL LIKE GAS. I THINK A CAM AROUND  250 D. AND 112 OR114 C.L. FOR CRUSING. JUST MY THINKING.
