dyno
Anybody had a strong 468-475ci engine on a dyno? I would like too see a dyno sheet of a 650-700hp motor in that ci range.
I found this build on a google search.  I know it's a little more cubes but, hey, it makes very good numbers for pump gas.  :smile30:
http://www.chevelles.com/forums/showthread.php?t=264055
532 ford, more cubes, but you wanted sheets.... :smile30:
'71 DOVE-C block from a Lincoln, 2 bolt main, ARP studs and Canton main girdle, bored .080, oiling mods
4.3 Scat light weight forged crank
6.8 Scat H beam forged rods
4.44 JE flat top forged pistons with 2 valve reliefs (approx 12.8:1)
Comp solid roller cam, 34-715-9 and springs to match
Isky lifters
Smith Bros push rods
Scorpion roller rockers 1.73:1
TFS Street heads,
Victor intake
Canton oil pan, windage tray
1095 Demon carb, HVH spacer
2" long tube fender exit headers
Are you trying to keep this on pump gas?  It's gonna be tough to make those kinda numbers on pump gas without building more cubes.
:smile30:
yeah i know, im going to bump it up to 11:1 compression. I cant make it too expensive to go boating. I do like to Cruise around some. Im just trying to see what rpm range the smaller ci motors are making 650-700hp. all my formulas say ill have to spin it more than 6500rpm to get 700hp with only 472ci?  :smile21:
Isky lifters
TFS Street heads,
Victor intake
Cant wait until i can spend a little extra to go 530ci!!!
I'd have to guess, but my old 429 w/ported dove heads, nasty .630 flat tappet, tunnel ram and 660's prolly hit on about 550-600hp....and it was 11 to 1.... :smile16:
C
CorDog009
Guest
I'll post mine up when I can get them scanned. 13.5:1 475 BBC.
C
CorDog009
Guest
Trying to attach them and see how that works..
C
CorDog009
Guest
Lol..tryin to resize it. Thanks, yea it runs pretty good  :smile17:
C
CorDog009
Guest
Carnivalride said:
What cam, heads and intake are you running? Nice numbers.  :smile17:
Thanks man. The cam is a Lunati 278/286 @.050, .718/.721 lift. Heads are Brodix BB2 Plus with a Brodix single plane intake and a Proform billet 950 carb. The nitrous system is a Richard O'maley cross bar plate kit. I believe it was jetted at a 300 shot there. It'll go up to 350hp. Not sure what crank/rods but the pistons are JE's.
Man thats some good numbers! That helps me alot thanks! If i can get my ford to put some numbers out like that ill be happy! I dont have the bottom end for the nos yet. If you wasnt using nos what impeller would you be running?
C
CorDog009
Guest
Probably still be running the same B impeller. This one is a stainless steel one with an inducer.
Thats one huge cam, 278/286 @.050!
undoubtedly......I think his is bigger than mine! :smile19: :smile28: :smile16: :smile23:
here we go................ :grin:
Oh, and i'll be here for the next few hours for your entertainment and abuse! :smile16:
Paid the shop off, and had a few shots of whiskey and a few buds..... :smile26: :smile16:
