Wow! To get the same dynamic compression from my new motor with the big roller as my current motor has with 9.5:1 static compression and small cam, I will have to setup the new motor up with 11:1 static compression!
that's why I compared the two. I had no problem running pump gas with the small motor. I could probably go to 12:1 and still get away with 93 and octane boost.EOSpeed said:THAT HOW YOU RUN PUMP GAS IN A 11-1 MOTOR.
Motor Head said:that's why I compared the two. I had no problem running pump gas with the small motor. I could probably go to 12:1 and still get away with 93 and octane boost.EOSpeed said:THAT HOW YOU RUN PUMP GAS IN A 11-1 MOTOR.
HammerDown said:Motor Head said:that's why I compared the two. I had no problem running pump gas with the small motor. I could probably go to 12:1 and still get away with 93 and octane boost.EOSpeed said:THAT HOW YOU RUN PUMP GAS IN A 11-1 MOTOR.
I am running 13:1 on Av
Knotty said:HammerDown said:Motor Head said:that's why I compared the two. I had no problem running pump gas with the small motor. I could probably go to 12:1 and still get away with 93 and octane boost.EOSpeed said:THAT HOW YOU RUN PUMP GAS IN A 11-1 MOTOR.
How much is AV gas in your area?
HammerDown said:Knotty said:HammerDown said:Motor Head said:that's why I compared the two. I had no problem running pump gas with the small motor. I could probably go to 12:1 and still get away with 93 and octane boost.EOSpeed said:THAT HOW YOU RUN PUMP GAS IN A 11-1 MOTOR.
Last year it was 3.80/gal probably be 4.80 this year LOL
Knotty said:HammerDown said:Knotty said:HammerDown said:Motor Head said:that's why I compared the two. I had no problem running pump gas with the small motor. I could probably go to 12:1 and still get away with 93 and octane boost.EOSpeed said:THAT HOW YOU RUN PUMP GAS IN A 11-1 MOTOR.
WOW that is good. I paid $5.20 last year.
Knotty said:I was going to the Air Port next week I will let you know the price then when I get it.
HammerDown said:Knotty said:I was going to the Air Port next week I will let you know the price then when I get it.
I am going to start buying it 50 gal at a time. Including Tawk I only used about 40 gallons last year
Knotty said:HammerDown said:Knotty said:I was going to the Air Port next week I will let you know the price then when I get it.
I used 40 gal. at Tawk alone last year, actually ran out and put 5 more in. Remember when Patch and I ran out in the middle of the track. crazy.gif
That's better than av gas! think.gifTintMan said:I used 3 barrels of sunoco 110 last year! 54 gallons=$365 :smile28:
