I have changed many of them yes you need a deep socket, you do not have to pull the clutchs all out are apart, and the one on the clutch I belive is right hand to lossen or vice versa, once you pull the keyway off pull the plate with clutch set screew off and the nut is under that then loosen the nut and pull clutchs and housing all off together, make sure when puting the wheel back on and tightin the belt, you have it stright, you also might have to pull the swing arm nut to get the belt on! its been about a year sence ive done one but I could for sure tell you when it was apart maybe some else can chime in! Like I said its been a bet! But not that bad!
