mech. bird catcher complete w/ barrel valve, lines, nozzles, check valves, hat linkage
80 a-1 pump w/ 3 way valve, crank drive pump pump belt assy. the hat is set up with 8 .30
injectors, 10 extra by pass pills ranging from # 100 to # 136. also an lines from pupp to hat.
appr. 6 to 8 hr's run time on this set up. well over $2000 invested. will swap for a set of
holly's 1050 1150 or 1250. or $1800 depending on you'r motor set up will probably need
smaller injector's the end's are around 8.00 a peice.
