glastornjet73
357ci has scat steel crank superlite i beam rods with cap screws not bolts keith black h102cp pistons comp solid roller cam insure on grind anymore i could look for the cam card i know i have it somewhere comp lifters comp stainless rockers brodix aluminum heads with all manley parts ported and polished port matched to a performance products power plus intake block is a 010 4 bolt 1/4 filled still streatable wont overheat cause of the hardblock everything is ballanced rite has a circle track pan and the correct pickup tube and brand new pump this would make a killer little engine for any application leave the pistons in it for a race application or put a set of flat tops in it for a monster street engine not hiding anything engine is apart for anyone to come inspect everything i say is in it is there it is fresh and has not been ran since new rings bearings and having the heads freahened but it has sat and it needs cleaned and reassembled asking 3500 call dj 618 920 2827 i am neer st louis but dont let shipping bother you i got a quote from fastanal to ship a 900# crate from central cali to me for around $75 also for those of you close enough i would trade for nice car or small v6 truck of equal value toyota camrys and honda accords and ford ranger will be givin higher consideration thanks
