soldier of fortune
i am listing my sanger hydro, it is 18' it is a two seater powered by a 468 bbc, i beam rod, flat top pistons, 270h hydraulic cam, 7/16 pushrods,harlan sharp 1.7 roller rockers,high volume oil pump,9 qt. oil pan,two 750 dp sitting on a tunnel ram,msd distributor, along with a msd coil,and msd 6Al box, exhaust is a set of water injected bassett headers with removable baffles,, the casale v-drive is a 12 degree, which was just gone thru by beaverfab inc. covington ,tx. it has 15% gears in it. Prop is a ron braaksma fat cleaver specifically designed for this boat. brand new throttle cable and steering cable.this boat has outboard steering, brand new bilge pump installed.the boat sits on a tandem axle trailer with four new tires installed. 6000.00 turnkey 727-871-3094
