After having a tire blowout on the Checkmate trailer I decided to change them all just for peace of mind. Thought I would pass this connection along in case someone needed trailer tires since most of the tire deals I found ranged from $75-$100 per tire. I had all four Carlisle 215/75/R14 radial trailer tires delivered to my door in two days for $227.00. All are 2016 dated tires so they are not old stock. Thought this was a pretty good deal from treaddepot.com.
QtyFETPriceTotalLabor / Service Discount
$25 INSTANT REBATE
Item Number: DCTDF251-$0.00$25.00$-25.00 Carlisle Radial Trail RH - Trailer
ST215/75R14 RADIAL TRAIL RH LRC
Item Number: 51513614$0.00$49.00$196.00 Shipping:$41.82Tax:$14.11Total:$226.93
View Larger Images | â–¶ Product Video
Carlisle Radial Trail RH - Trailer Radial Trail RH - Trailer
(34)
Tire Size: ST215/75R14 (- -)
In Stock
$49.00
ADD TO CART
SHIPPING QUOTE PRICE MATCH
SPECIAL OFFER: Instantly Save $25 On A Set Of 4 Tires
FEATURES AND BENEFITS
Carlisle's best-in-class trailer tire, The Radial Trail RH is a new trailer tire for Carlisle that surpasses its predecessor in every way. Featuring superior heat resistance and sway control, as well as a belt package that ensures high strength and long life. Carlisle Trailer Tires are enhanced with ozone and weather inhibiting compounds to minimize the effects of dry rot as well. Pictured wheels are for illustrative purposes and are not included.
Tire profile and tread compound formulation create lower rolling resistance and increased fuel mileage.
Equipped with the DuraTrail high strength belt package and HeatShield heat resistant compounding technologies.
A proven leader both in field tests and by independent laboratory testing.
SPECIFICATIONS
Mileage Warranty: N/A
SideWall: Black Wall
UTQG: -
Performance Rating: -
Load Index: -
Load/Ply Rating: C - 6 Ply
Load Capacity: 1,870 lbs
Overall Diameter: 26.80"
Tread Depth: 10/32nds
Section Width: 8.20"
Tire Weight: 22.60 lbs
Maximum PSI: 50
Run Flat: NO
OE Specifications:
$25 INSTANT REBATE
(34)
In Stock
$49.00
ADD TO CART
SPECIFICATIONS
UTQG: -
Load Index: -
Maximum PSI: 50
Run Flat: NO
OE Specifications:
